Go Kart parts!
Calzonii - 23/5/15 at 11:08 PM
Hello folks,
I have recently got an old go kart chassis and am starting to built it into a working kart for use around my garden. I have raised the kart by 1.5 inches for a bit more ground clearance.
I do however need some bits of kit that I cant find but really am hoping not to spend a lot of cashmoneys on it so thought Id put a post up asking any kind fellows on here who have some old parts lying about to sell them to me at a cheap price
A list of what I need is.
1. A centrifugal clutch for 19.05mm / 0.75in drive shaft. (With key)
2. An engine-chassis bracket plate for Honda GX200 engine.
3. Accelertor and brake cables.
4. A complete brake system. Caliper, Master cylinder, disc and carrier for 25mm axle.
5. 25mm stub axle spacers to space front hubs.
6. Steering column boss
7. Seat mounting brackets
Thanks to anyone who can help!
Cal
tims31 - 24/5/15 at 09:19 AM
Hi,
Maybe put up an ad on the UK Karting website. there are loads of friendly people on there who may just have some of those bits lying around they need to get rid of.
HTH
Also, just re-reading your post, you will need to know the spacing between the chassis rails to determine what engine mount bracket is required, some chassis have different spacing.
[Edited on 24/5/15 by tims31]
Calzonii - 24/5/15 at 11:35 AM
Thanks tims!!
