Help we have been trying to help our daughter with her homework. Question Create a graph from each of the following functions. Use the starting points
given with each function to find co-ordinates.
We are stuck on one of the questions.
y = 4x -3
{1,2,3,4}
We know how to calculate them but are not sure how to put them on the graph ie which way do they go.
when calculating the numbers the answer does not have a minus in front of it does this mean you go diagonaly upwards or do you treat the coordinates
as minus and go downwards from zero. Any help will be appreciated as we are stuck and she doesnt want to go back to the teacher on Monday and get told
off for not listening properly. Graham [Jacko
if it helps y is up and x is across.
Hi
Have a look at the graph in my picture archive (called graph for jacko). I'd have added it to the post but i'm not sure how to get pictures
in!
Hope it helps
Matt
aggghh, just wrote full explanation but not logged in so lost,
anyway, here we go again.
as mentioned the "y" refers to the vertical (up) axis and the x to the horizontal axis. positive is going up for y and to the right for x.
the gradient of a line is the change in y divided by the change in x, a positive gradient going from bottom left to top right.
to get the curve plot the numbers given (presume for x) against the correspnding value for y (or the other way round)
ie
x = 1, y = 4 x 1 - 3 = 1
x = 2, y = 5
thebn get the gradient by the above method
trick: all straight lines have an equation in the form of y = mx + c, where m is the gradient and c is the intercept with the y axis. therefore your
daughters graph should cross the y axis at -3 and have a gradient of 4 (sloped as described above).
hope this helps,
zane
A note about my previous post - In that picture the x-axis begins at 1 which is bad practice and should start at zero. Hence check out 'Graph 2
for Jacko' in my archive. Should get full marks!
Matt
Sometimes i wish i could go back to maths like that...
Beats second order differental equations any day....
Many thanks to everyone who replied to
my daughters dilemma. Excellent graph Matt and excellent explanation Zane we have printed off the answers so she can keep it in her school bag.
from Graham and Amanda the daughter. Back next week with the next maths problem no doubt.........
Originally posted by mattpilmoor
A note about my previous post - In that picture the x-axis begins at 1 which is bad practice and should start at zero. Hence check out 'Graph 2 for Jacko' in my archive. Should get full marks!
Matt
make it a 4 segment graph, showing -20 to +20 on the y-axis, and -5 to +5 on the x-axis, centred on 0,0. Then it really will go down well!
Sometimes i wish i could go back to maths like that...![]()
Beats second order differental equations any day....![]()
Matt
Oooh, I dont know about that y-axis starting at -5 either!!I always thought the origin ought to be at (0,0). Er, loose one mark!
Liam
technically graphs are meant to start at 0,0, its just people are slack, hence graphs in media (news or advertising)often just start where they want. But i think in school stuff it would be bad practice not to start at 0,0.
