This may seem a bit of a weird.
i have seen a kit based interceptor from mad max which uses the capri chassis.
i was wondering if anyone has seen a mustang kit using a capri chassis any help will be greatly welcomed
Not using a capri, and seems only to come part built, but the only Mustang conversion I've seen (in the uk) is the Mill Auto Conversions one:
about half way down here:
http://www.totalkitcar.com/tkc_article_1348.php
There are probably some in the states, but they won't be on a Capri donor either.
why not just get the real falcon? a capri will always look like a capri due to the shape of the back and none of the conversion kit panels will fit to
make a max max car...
http://www.aussiecoupes.com/max.html
how many times have I watched those films?! Virtually know every line..
'What wrong Max you've seen you've heard and your still askin questions!?'
When they first started that engine up I almost fainted! almost.
[Edited on 5/4/07 by Mr Whippy]
