A mate has a Fiat Punto 1.2, I think its a 2000 model.
The airbag light has come on.
Any common faults ?
He did say they have been sliding the passenger seat back and forth a lot recently so you know what I am thinking, but I will ask on here anyway
because its wrong to presume.
Cheers.
Steve.
There is only one thing you can do: make a diagnosi with computer, there is no common fault, the only common fault is passenger airbag swithc (it have
a non idoneus wiring loom, in this case you have to change wiring loom ( about 5 euro)
BTW if you can not connect a computer you can do nothing.
Maybe you fault is intermittent but you can't reset errors without computer.
Rudy,
Your english is better than some english peoples.
Yes I did say to the guy that he would probably need to get a garage diagnosis, but its always worth a try.
grazie
Steve.
Have a look at this thread from the Fiat Forum
http://www.fiatforum.com/punto-technical/97542-airbag-warning-light.html
Looks like an easy cop out for me, I did not want to get too involved, It looks like a visit to the dealer,
Thanks,
Steve.
Is it like the standard Punto airbag, but without the sugar and caffeine?
Thanks,
Steve.
He did say they have been sliding the passenger seat back and forth a lot recently so you know what I am thinking, but I will ask on here anyway because its wrong to presume.
Cheers.
Steve.
Originally posted by Humbug
Is it like the standard Punto airbag, but without the sugar and caffeine?![]()
it took me far too long to get that
Cheers.
Steve.
We need to know the real reasons for the seat being moved back and forth![]()
[Edited on 13/6/07 by TGR-ECOSSE]
I am far too polite to ask questions like that, But I reckon Hanky panky could be invloved, quote:
Nope still havent got it !!!#
Regards
Agriv8
As already sugested in most makes of car Air bag lights are usually caused by bad connecions under the seat -- the gasses seat foam and pyrotechnics
and disimilar metals seem to cause corosion problems.
Usual cure is pull the connections apart clean with switch cleaner and protect with silicone grease or wd40.
REMOVE THE KEYS FROM THE IGNITION FIRST AND KEEP THEM WELL AWAY FROM THE VEHICLE and also pull the airbag fuse while carrying out the work.
[Edited on 13/6/07 by britishtrident]
all this advice are good
however you can do everything , but without computer to reset errors light will be always on.
