Heat Resist Paint
The One - 27/1/04 at 07:26 PM
I'm looking to paint my pinto and box. Has any one got a reliable source of suitable paint.
shortie - 27/1/04 at 07:57 PM
Halfords seem to do a fair range of colours.
TPG - 27/1/04 at 09:50 PM
Hamerite.F%$@&! by the stuff for engine and transmisson.Or other copies of hamerite.You can mix up any colour you want with the range avalibe.
stephen_gusterson - 27/1/04 at 10:32 PM
Standard Hamerite absolutley DOESNT resist heat.
the hammerite site says if its too hot to touch, its too hot for hammerite.
Hammerite isnt actually very good. I used it to reaonable effect on my sump and bell housing, but the blaock on my air filter box looks like I did it in treacle
atb
steve
PioneerX - 28/1/04 at 10:12 AM
International do a great heat resistant paint, it's about £6 a tin down you local B&Q. I've used it on engine parts (except the exhaust manifold). It's heat resistant to 200C. I've had no problem in the past with it. The tin I use most of is the black gloss, great finish & the little tins go on and on and on. Great value for money and hardy.
Simon
splitrivet - 28/1/04 at 01:47 PM
Ned reckons 2 pack would be Ok.
Dont rate Hammerite at all did my diff with it and its red rusty now,and smoothrite chips like the clappers
Bob
The One - 28/1/04 at 07:20 PM
Cheers everybody.
I have heard 2 pack cracks with time.
Jimbo - 29/1/04 at 10:47 PM
I use household radiator enamel paint from B&Q, it's the best that I've found, but does take 4 hours to dry.
Hammerite is the worse paint that I've every used.
