Plumbing my Pinto expansion tank
James - 3/2/04 at 03:01 PM
I'm using Pinto, Micra Rad, 40's
I've read as many posts on this as I can- still a little unsure.
Pretty sure I'm right in thinking that the outlet of the expansion tank (bottom connector) should go to the 'little' pipe on the pump?
When it comes to the expansion tank inlet (top connector) I appear to have a choice: Micra rad cap (little pipe), thermostat bleed pipe or cylinder head outlet (via manifold).
Assuming I've got all these the right way round- which is the best of the three to use?
Thanks,
James
timf - 3/2/04 at 04:07 PM
james
the small w/p and manifold should be connected together and the bottom feed of the tank tee'd in to this.
the top connection should go the the highest point of the plumbing runs.
Tim
Avoneer - 3/2/04 at 05:30 PM
Mine is as follows (as is most Tiger owners) bearing in mind that the Tiger supplied radiator has a large outlet at the top, a large one at the bottom and a medium one at the bottom:
Top of header tank (small) to small outlet on thermostat.
Bottom of header tank (medium) to bottom of radiator (medium).
Top of radiator (big) to thermostat.
Bottom of radiator (big) to water pump (big).
Water pump (medium) to inlet manifold (medium) (via heater if fitted).
I have a pic which I will try and find now and post.
Hope that confuses even more (he he),
Pat..
Avoneer - 3/2/04 at 05:33 PM
Pic as promised....
Courtesy of http://www.cate1.co.uk/ Rescued attachment plumbing.gif
James - 4/2/04 at 03:41 PM
Hmmm, I'm a bit more confused now as you seem to disagree with each other!
I believe I've seen it done with the c/head outlet blanked off as well!
Maybe it doesn't matter and all combinations work!
Thanks for the advice,
James
James - 4/2/04 at 03:43 PM
Assuming I use the outlet from the c/head through the manifold I'll need the special screw in pipe that goes into the manifold.
The one on my 32/36 weber is a much bigger thread. Any idea from where I can get the 40's manifold type?
Thanks,
James
Avoneer - 4/2/04 at 05:32 PM
I got mine from Tiger, but I think they sell the same one in screwfix or machine mart (and it's a lot cheaper).
Pat...
jacko - 4/2/04 at 10:04 PM
James
Iv piped my pinto +micra rad
inlet manifold to top of header tank
bottom of tank to small pipe on water pump
my mate has just piped his from rad cap
to bottom of header tank and top pipe
to atmosphere
his works ok i have not tried mine yet ?
jacko
