Anyone know where i might be able to get some bits required for some Suzuki carbs (besides Suzuki main dealers)??
I need a few viton o-rings (6mm) for the inter carb fuel lines and also a small spring that pushes the inter carb linkage against the adjuster
screw.
Any suppliers out there that anyone has used??
Also, can anyone recommend a jet size for a standard 2L Pinto to get the car through SVA and to the rolling road. Standard ones are 125's which i
am guessing might be a touch small. Is there anything other than jets needs doing to the carbs such as air holes getting blocked etc??
Ta muchly
[Edited on 12/2/09 by Paul TigerB6]
I'm running 1.6 mains with my ZX6R carbs which seems about right [2.0 Zetec].
I'll have an ARF meter on it soon so should be able to give a better answer then.
Stu
Paul
Suzuki doesn't make the carbs. They will be Keihin or Mikuni carbs (see your carb for details ). Any bike shop, and certainly any dealership
with a dyno on site should be able to sell you jets, alternatively contact the importers for the appropriate brand.
I need a few viton o-rings (6mm) for the inter carb fuel lines and also a small spring that pushes the inter carb linkage against the adjuster screw.
Also, can anyone recommend a jet size for a standard 2L Pinto to get the car through SVA and to the rolling road. Standard ones are 125's which i am guessing might be a touch small. Is there anything other than jets needs doing to the carbs such as air holes getting blocked etc??
Ta muchly
ive got a set of 4 mikuni main jets 165 size which were to big for my zx6 1600cvh setup and a spring 10mm long 6mm dia if of use £10 posted, otherwise
should be able to get universal Orings and springs to suit and jets from a mike shop with a dyno
