stripped the bottom end of the pinto this morning so that i could do the honing (which all went well) and then inspected the crank main bearing and
one of them has a crack in it! i measured the crank and it measures 56.98mm, consulting the oracle of Haynes its has standard crank width so is it a
case of just buying and fitting a new set of bearings?
would these be ok
ebay linky
Alex
[Edited on 21/9/09 by omega0684]
Yup.. will be fine as long as the crank
isn't damaged.
just be glad you spotted it now
Can't see the auction because at work, but the link says big end bearings and you say the mains are cracked?
He must be talking mains as big end is 51.98 - 52.00mm
Time for that zetec?
no NOT the big end bearings of the conrod, i mean the main crank bearings that hold the crank in the block.
above link corrected
here
Yep, the auction is for big end bearings
You need mains.
I would add a 'BIG' between the two words in your thread title (preferable in bold)!
The initial statement just doesn't convey the seriousness of your predicament!
just for scootz, title amended!
lucky bugg3r if you ask me, noticing now and not finding out the noisy way!
Rich
I thought from the title you were boasting!
just for scootz, title amended!![]()
hi alex,
i take it you would have fitted new mains anyway,
'if there was no crack'
