Zetec to Pinto ~ Starter Motors.
The Baron - 2/12/09 at 04:56 PM
This is the last part (i bet it wont be) that i need to source for my winter project to replace my pinto engine.
I know the usual starter is a lucas lrs707, but several articals also state that a starter from a Diesel Escort can be used when using a Type 9 gearbox.
Does anyone know the model number of the one which fits, there seems to loads of cheap ones on ebay, but which one?
Cheers in Advance,
B
Spot the mistake in the title???
should be Pinto to Zetec
[Edited on 2/12/09 by The Baron]
austin man - 2/12/09 at 05:16 PM
I m aware that the following can be used Pinto starter with a 14mm spacer plate, 1.8 CVH or 2.00 DOHC starter (sierra and Granada for the DOHC)
Remember water pump needs changing if the engines out of a mondeo as they rotate in the opposite directionand the sump needs modding where the starter is as it fouls
coozer - 2/12/09 at 05:49 PM
DOHC starter on mine, NO sump mods for the silvertop, few ribs ground off a blacktop sump.
An idler is easier to install than spending the cash on a new water pump (unless you want to)
Heres the label on the side of my starter.... Rescued attachment DOHC Starter.jpg
norfolkluego - 2/12/09 at 07:43 PM
Sump mods before/after Rescued attachment sump1.jpg
norfolkluego - 2/12/09 at 07:44 PM
With thanks to Numb nuts, his engine/garage Rescued attachment sump2.jpg
norfolkluego - 2/12/09 at 07:45 PM
PS the shiney one is after
austin man - 2/12/09 at 10:38 PM
is the black top sump a direct replacement for the silvertop one ?? I retained my alloy sum had it shortened and modified to clear the starter.
What is the cost of the black top sumps
