Anyone know where i can get a set of steel flanges for my TD04 turbocharger?
Ive made great progress with the oil return etc, but i need the flanges now by the end of the week, or ill be delayed as ill have to go back to
work.
I need a TD04 / T3 adapter, and a TD04 exhaust plate with the five holes to fit over the existing studs.
The T25 (Garrett) is significantly smaller, so i cant modify the existing and i cant find anywhere that does TD04 bits.
do you have pictures of wat you need ?
ive got t3/t4 flanges thats all .
otherwise im at work starting 4th jan .
Not currently. The turbo i have is an Impreza tD04 with the triangle shaped flange to the exhaust manifold. The manifold i have is currently a T3
flange so i need an adaper to suit.
Boggle is also on the case for me, and has been a great help so far, but just wanted to see if i could get something this week.
The five stud flange covers the exhaust turbine and the wastegate and would normally have an elbow attached to it. I just need a plate to cover it
with a 2" (2.25" hole for the new exhaust which i have yet to make.
Does this make it any clearer without pics? Sorry if it doesnt, ill try and get some photos uploaded.
have just had a thought....
can post you a tdo4 flange tommorow!!!
got one on my old subaru up pipe!!!!!
Cool, ill send you my home address.
Ill take anything youve got tbh, ive got a centre section from a WRX (2.25" which i plan to use bits of, so the more ive got the better
really.
Thanks again.
Have got five in shed stainless steel lazer cut will cost you a 1 ltr bottle of harveys bristol cream sherry. (10mm thick).
The five bolt one. Turbo to down pipe.
[Edited on 29/12/09 by madteg]
Think the Volvo 850 T5 was a rectangular plate from distant memory.. May help.
TT
I got all my turbo flanges and adaptors etc from the USA, cheep as chips compared to uk. however you do have to wait for delivery
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=turbo+flange&_sacat=See-All-Categories
TT
ok...another one to try is
http://solid-fabrications.co.uk/flanges.aspx
mitsubishi turbos fitted to volvos share a t3/t4 footplate .
the turbine outlet (ie downpipe) is always a 3bolt flange to a conical outlet to fit the downpipe flare , or a flat flange which is just bolted
straight to the turbine outlet (and more desirable of the two) .
the turbine outlet (ie downpipe) is always a 3bolt flange to a conical outlet to fit the downpipe flare , or a flat flange which is just bolted straight to the turbine outlet (and more desirable of the two) .
i will send you the whole up pipe tommorow mate.....you can chop as you need....
TT
Thanks, the T5 is different to the T3 and T4.
TT
T5 in this case being the car model, not the type of turbo fitted!
T5 Stands for "Turbo 5 Cylinder"
I Know it's a bit confusing!! Like when you see a tiny little volvo S40 T4!!! Can you imagine running a T4 turbo on something like that
The Volvo 850 T5 Runs a
TD04-HL15G from memory on a rectangular flange.
The 850 T5R uses the same turbo
The 850 R uses a "16" IIRC
The V70 R uses a "19" IIRC
It's been a few years since I had my 855 though.
TT
Money and U2U Sent!
Thanks.
are you collecting flanges now???
