Just as a curious speculation, does anyone know the suitable size / which bike throttle bodies would be best for a BMW M44 engine 1.9 16v?
Also would a remap of the standard ECU be a) necessary b) sufficient or will an after market ECU (such as megasquirt) be needed?
There is a bit of information on the BMW forums about throttle bodies (M3 etc) but I couldn't find any on bike bodies.........plus we all know
this is the best place for information!
why not cut down some bmw throttle bodies?
There is a bit of information on the BMW forums about throttle bodies (M3 etc) but I couldn't find any on bike bodies.........plus we all know this is the best place for information!
Yeah the M44 has a single throttle body and MAFF which is why I was wondering if the ECU actually needed remapping / changing.
The E30 M3 had individual bodies as did M powered straight 6's.
I was thinking bike bodies due to ease of sourcing them at an affordable price.
Any ideas which ones are suitable?......GSXR 600's.....750's.......Hayabusa??
have heard GSXR 600 can do 175bhp 750's 200bhp, benefit is if BMW do an alternative individual throttle bodier you may be able to reuse your injectors which flow matches your ECU and no hassle with making a inlet manifold, respace ect. if you are considdering trying to use the BMW ECU you need to all the orignal matching sensors, injectors etc
Would you say theoretically then, one could make a manifold (possibly butchering a standard one) respace some bike bodies, use standard injectors form
the BMW and utilise the MAFF and the rest of the sensors whilst running it on the standard ECU....?
That might be hassle for little or no gain.
Alternatively source a larger single throttle body and run the rest as standard....?
I suppose to get the biggest gains you would want to use an after market ECU specifically mapped to the new set up.
Will, what improvements have you noticed with yours?
The most common thing people do is to put a bigger engine in (325, 328 M3 etc), like you say, but I wanted to exhaust alternative avenues first before
doing the normal thing.
It is probably the most cost effective power increase but I can't help thinking it's cheating!
Thank you for your input, I shall do some more investigating.
