Hi,
just got around to fitting a choke cable to my ZX6 Carbs & the solderless nipple is catching on the body of the carb meaning I can only open the
choke less than half its travel.
I assume that the solderless nipple I'm using isn't suitable, but to save me time (& effort - I'm a lazy b*****d) searching, can
someone point me in the direction of one that'll work?
Ray
Cut the nipple off and use the metal bit from the inside of the chocolate block electrical connectors.
Cut the nipple off and use the metal bit from the inside of the chocolate block electrical connectors.]
i think i used a universal bicyle brake cable.
thanks for the responses chaps - have ordered a ZX6 choke cable - need to see it in front of me to determine how/if I can use it.
Ray
