Hi All, I am now using cortina points distributor and have actually run the beast briefly,however I have just realised the black plastic pipe coming from the pressure regulator/valve(small gold filter thing)is a return pipe and not overflow.Not wanting to run a return pipe back up my chassis what do I do with or where do I connect this pipe??Do I need this reg.valve at all or can carb cope??Answers pleeese!!!!!Mike.
Those valves were allways giving problems and i just disconected them,never had a problem with flooding.
