Pinto 2.0 with twin 40`s and i find the clutch only slips when changing from 3rd to 4th?? perfect from a standing start ie 1st to 2nd and 3rd but
slips when 4th..
suggestions?? just the plate ? bearing ? or the whole lot? if so what you lot running?
once again pinto 2.0 carb type 9
First check the clutch fork is clearing OK otherwise - new clutch required.
