are the silvertop and black top sumps interchangeable ?
You can put a silver top sump on a black top with four 20mm spacers and four main cap bolts from a silver top but not vice versa as the black top has higher main bearing caps to allow for the cast alloy windage tray.
If anybody's done this I'd appreciate a pic!
