HI all
I have just bought a 2.0 duratec im picking it up sunday afternoon and would like to now what else i would need from the mondeo for this engine and
what bike TBs and ECU would you recommend.
many thanks
Mark
[Edited on 28/5/11 by hootsno1]
Originally posted by hootsno1
HI all
I have just bought a 2.0 duratec im picking it up sunday afternoon and would like to now what else i would need from the mondeo for this engine and what bike TBs and ECU would you recommend.
many thanks
Mark![]()
Omex ECU and R1 throttle bodies should do the job nicely. Or any 42-45mm set of throttle bodies
Use the injectors in the cylinder head rather than the ones in the throttle bodies. Gives a lot more scope later on. Just blank off the holes in the
throttle bodies where the bike injectors fitted.
Flat monkey do you now what year r1 tbs i would need please.
You want 2001 GSXR 750 ITB's they are 42mm same size as Jenvey, you can get a Manifold from FastDan on here he made mine and also get engine
mounting brackets from him as they are difficult to source at reasonable cost. Here's some pics
[img]
Bracket
[/img]
[img]
Throttle Bodies on Duratec
[/img]
[Edited on 29/5/11 by big-vee-twin]
hi there, i went with megasquirt and gsxr750 throttle boddies. but if i were to do it again, it would be with omex and a set of jenveys.
stu
I have a few sets of bike bodies (inc r1) in stock so can put you a manifold and bodies package together if that's the way you want to go. As said I also supply engine mounts to suit the locost chassis.
Hi Stu,
I got a duratec and deciding the same thing as hootsno1, between bike TB or Jenvey or anything else that would be for a quite good price/power ratio.
Why would you go next time for omex and Jenveys?
Do you know what is the performance gain between bike ITB and Jenveys?
Originally posted by Longerr
Hi Stu,
I got a duratec and deciding the same thing as hootsno1, between bike TB or Jenvey or anything else that would be for a quite good price/power ratio. Why would you go next time for omex and Jenveys?
Hi Stu,
hi there, sorry for a late reply,
next time i would go omex and jenveys, simply because the tunning of omex would be easier to get done for me, and looks.
stu
