Hi all,
I am painting the pintosaurus with foliatec caliper lacquer (also does engines)
According to the instructions there is a spray can of cleaner then a 2 pack lacquer that goes straight onto metal.
Just wondering if i should use acid etch primer first???
Andi
No need as long as its clean. I did mine about 6 years ago. Its not on the road but is run up most week ends. Looks as good as new.
Check on Halfords website and instore. They are clearing out old stock of every colour BUT red.
Its a tiny tin thats less than half full but it will do a full block and more.
Etch primer is NEVER a waste on bare metal
