Supercharging my Zetec
jeffw - 9/11/11 at 09:37 PM
So I'm about to start ordering up the parts I need to supercharge my Zetec. I'm going to go for the Omex kit which includes the mounting brackets, tensioner system, Rotrex, alternator & belts etc. This will mean I can run my Omex 600 with the kit and it should do 260-270 in low boost mode (0.5-0.6) which will be safe enough before I change the rods & pistons and run it upto 1bar.
To fit this kit I need a intercooler and a plenum. I think the best way forward on the Plenum is to use the GTiR Plenum which Flak used for his Duratec build and get someone to design and cut a new back plate for the GTiR plenum to mount on my 45mm DCOE spaced Jenvey throttle bodies. Is there anyone on here fancy taking on the work?
I'm also going to need to run a MAP sensor of the inlet manifold so I will need to get this balanced across all the inlets. Any ideas on how to achieve this?
I reckon charge cooling will be easier to package into the Phoenix than intercooling. Anybody any thoughts on that or a good source of a charge cooler kit?
I love winter upgrades
matt_gsxr - 9/11/11 at 10:09 PM
Jeff,
Intercooling isn't as bad as you might think in the Phoenix. It is much easier than in a seven as your inlet/outlet hoses can use the space under the bonnet so you can have a standard FMIC.
I too had worried about it, but saw the factory Red supercharged Phoenix at the Stoneleigh show and they had put an intercooler in this location. So I copied it.
Temperatures used to get to 60deg under boost (without it), but now they hardly flinch (except at idle) although I am only running 9psi.
I preferred intercooler as it is lighter, cheaper, simpler and doesn't require any additional electrical power. Anyway here are a few photos, which might explain what I mean.
Mine was a cheap intercooler from e-bay (UNIVERSAL 2.5" FRONT MOUNT INTERCOOLER 595x175x65mm, from the embarassingly named 2fast2cool, £80) which is shiny and seems to work, but I am sure you can source a more distinguished item. Before anyone starts, yes I know 2.5inch is larger piping than necessary/optimal.
Matt
https://lh4.googleusercontent.com/-Ldx pqiv6q4c/Te_zYQbTR8I/AAAAAAAAA54/wnuVLQanCMI/s576/DSC02075.JPG?gl=GB
https://lh4.googleusercontent.com/-1MS heR37cRg/Te_zVZHXIeI/AAAAAAAAA50/ztuNofC3TeU/s720/DSC02074.JPG?gl=GB
https://lh3.googleusercontent.com/-9lw tW5yPDtQ/Te_zR2DgbNI/AAAAAAAAA5s/r_4pteWUXWY/s720/DSC02072.JPG?gl=GB
https://lh3.googleusercontent.com/-txJ DQkpqnJ8/Te_zcQs6BvI/AAAAAAAAA6E/387Vaz4S5Po/s720/DSC02078.JPG?gl=GB
edited to sort my pictures out.
[Edited on 9/11/11 by matt_gsxr]
djtom - 9/11/11 at 10:12 PM
Depending on cost, I'd be interested in getting a backplate for a gtir plenum too - I've been meaning to make one up for ages but have never got round to it.
I was thinking something along these lines, but to be done much much cheaper - £1300 for an new intake system is
My version will use a set of gsxr600 tb's I have knocking around.
I did speak to the guy to see if he could get more made, but he paid over £150 for a backplate and a spacer which I thought was a bit much.
Tom
dlatch - 9/11/11 at 10:16 PM
interesting stuff and i hope there will be a project thread to follow on this conversion jeff
madteg - 9/11/11 at 10:28 PM
DONT FORGET TO CHANGE THE ROD BOLT TO ARP ONES.
MakeEverything - 9/11/11 at 11:20 PM
Just drill and tap the manifold to accept the sensor, or introduce it into the pipework entering the manifold. The pressure in the manifold is what is seen at the TBs.
jeffw - 10/11/11 at 06:24 AM
ALREADY DONE
snapper - 10/11/11 at 06:29 AM
The megajolt way is to drill all 4 runners after the bodies run 4 pipes to a small plenum box then run 1 feed to the map sensor.
The small plenum 2x2x4" smooths out the individual runner pulses.
The pressure head side of the throttle plates will show negative at idle to low throttle openings
1 bar absolute at WOT until boost comes on when over 1 bar is seen
Back to negative as throttle closes although the main plenum can show positive pressure.
jeffw - 10/11/11 at 06:38 AM
Thanks for the info, just need to get someone to make the backing plate now
jeffw - 10/11/11 at 06:45 AM
Originally posted by matt_gsxr
Jeff,
Matt
That is interesting Matt. I see you have the same Plenum as well, who did your backing plate? What is the ideal diameter pipework for, say, upto 350BHP? And where did you get the ali tube from?
jeffw - 10/11/11 at 06:46 AM
Do you have a source for the plenum and pipework?
jeffw - 10/11/11 at 06:57 AM
Tom
Well the Jenvey Plenum comes in at around £650 including machining so £150 + £45 for the GTiR plenum is pretty cheap. I was hoping that one of the many talented guys on here would like the work rather than me tracking down a commercial company.
will121 - 10/11/11 at 07:25 AM
Don't know if its of any help but seems in a zetec turbo conversion using a rover inlet manifold arrangement is a common modification
jeffw - 10/11/11 at 07:47 AM
I already have a set of Jenveys on the car so need to get a plenum for that rather than the engine itself. Nice idea though.
matt_gsxr - 10/11/11 at 11:18 AM
I machined it from tufnol using a router in my shed (see this thread. http://www.locostbuilders.co.uk/viewthread.php?tid=149161 ) I had some black tufnol kicking around so it was an easy job.
Can't flak monkey make you up a back-plate, I though he was selling his services and he has done nearly all of what you are doing (okay on a duratec) I know he has already drawn up the backplate so could easily get those cut.
The inlet piping and intercooler can introduce a pressure drop if too small. If too large then you can get boost lag (not sure whether this is the same problem on a supercharger). Can't remember about my calcs, but I based it on 250bhp and 2inch was big enough, Flak based his on 300 and 2inch was big enough (although his airflow route is very tidy). I think 2inch is limited to about 500cfm, (about what you need for 350bhp) but then your flow will be at around mach 0.34 (250mph air flow) and you will probably get a lot of pressure drop especially as the intercooler piping route will have a few 90's. To be honest I need to look at a book again to revisit this. I would recommend the Graham Bell forced induction book, this addresses turbos and supercharging. It is a fairly easy read (very practical, not 100% sure of accuracy) and I learned a lot from it.
Probably 2.5inch might make more sense if you are going for 350bhp, not sure.
Matt
jeffw - 10/11/11 at 11:59 AM
I was looking at the kits on ebay and I reckon that 2 1/4" would be the answer. Flak (David) is going to sort out the plenum for me. Looks like this is going to be fun
Just re-read your other post regarding the diameter of the GTiR plenum and the 2.25" would be ideal as it is 57mm and then plenum is 56mm. I'm going to get an intercooler which has entry and exit on the same side so I can run the pipework down the drivers side which will be out of the way of the water pipes and the exhaust.
[Edited on 10/11/11 by jeffw]
matt_gsxr - 10/11/11 at 01:28 PM
Jeff,
2.25 sounds like a good compromise.
If you have one of those intercoolers where the flow goes through one way and back, then I think they can be slightly more restrictive. If you think about how the air flows it is obvious why. Probably not a big deal but worth consideration.
The plenum is quite thick material (so my 2.5inch silicon bends fit over snuggly) I don't think you could stretch a 2.25inch to go over it. It gets a bit complex as silicon bends are measured with the diameter as the i.d. but tube is measured with the diameter as the o.d. nothing too challenging, but that silicon hose only stretches so much.
Sounds like a nice project.
Matt
jeffw - 10/11/11 at 01:42 PM
Ahhh, OK 2.5" sounds better.
matt_gsxr - 10/11/11 at 04:17 PM
You could start with 2.25 and then expand along the length to 2.5 where it meets the plenum. There is an argument that says you want to slow down the inlet charge when it gets towards the engine so that the effects of momentum don't dominate its flow behaviour. If momentum did dominate then all the flow would go into the end cylinder, which would stuff up your fueling (lean at that end, but rich on the others). So expanding gradually along the length can't do much harm. One solution to this is to have a reasonably voluminous plenum (which the GTiR one is).
I doubt it would make much difference, especially as you are supercharging which is less sensitive than with a turbo.
350bhp sounds like a lot.
Matt
jeffw - 10/11/11 at 04:24 PM
350BHP is about what the VAG guys get out of a stage 1 1.8T so in real terms not that much. With 1 bar and the other mods on the engine 340-350 is about right, the supercharge will make 1.4 Bar which would see it up over 400 but that is probable a step too far.
To start with I'm going for 0.6Bar which should get the engine to 260 ish and then later on we can change the rods and pistons and get over the 300 mark with a different pulley.
matt_gsxr - 10/11/11 at 07:20 PM
I meant a lot for a 500kg car designed for about 100bhp doing sprints often with bugger all run-off.
jeffw - 10/11/11 at 07:56 PM
But that's the thrill This is from Goodwood earlier in the year, talking about no run off lol
