I'm just at the stage of collecting the bits got most of the ford bits just need to order the megajolt
I was hoping someone could help me out with a map to get started it's a standard pinto only mod is a pair of dcoe 40s anyone got a map they could
share please
I've just done a similar search and had some great info from mcerd1 and dave r for some TPS based pinto maps.
U2U me your email and I'll send you a link.
Ian
u2u me your e-mail address
I've got some tps based ones
[edit] too slow
[Edited on 29/11/2011 by mcerd1]
Damn! you're fast...
That was quick wasn't expecting replies that quick
Will send you both a u2u now
link sent
there are some basic maps I've collected from a couple of folk, inc. some 2D ones to get you started
dun too...
have fun
Thanks alot il check them out when I get home on a proper computer I will download a copy of the megajolt software too
Autosports labs site has a users maps forum.. worth a look. loads of 4 pot pintos on there.
Tried a couple on the computer and they load up on the mljl software so thanks alot guys just need to get the rest of the bits including the
megajolt
They all have more max advance than I expected to be honest
[Edited on 30/11/11 by Autosri]
The advance in the partial to closed throttle position can be way more than the WOT number.
This is pretty normal from what I have seen, as this is where I am hoping to regain some economy when I replace my strictly 2D distributor with the
Megajolt.
Yeah I know you run more advance at part throttle as that's the purpose of vac advance was just more than I expected lol
Same here mate fuel economy is crippling with webers and a non vac advance dizzy So hoping it will be better to drive and be A tiny bit cheaper to run
lol
How far are you through your install
