stuck on clutch for rwd redtop
Jamster1233 - 18/2/12 at 11:38 PM
any ideas the correct clutch plate for the rwd redtop to type 9 ?? thank you guys
blakep82 - 19/2/12 at 12:40 AM
Clutch plate from a 2.3l diesel sierra is the one.
stevepj - 19/2/12 at 07:48 AM
Here you go
Clutch Plate
omega 24 v6 - 19/2/12 at 08:43 AM
From memory on mines as said 2.3 diesel sierra friction plate. Std redtop pressure plate and very vaguely a release bearing from a ford. DO NOT forget the spigot bearing as well.
Jamster1233 - 19/2/12 at 11:58 AM
thank you soo much guys really big help
Jamster1233 - 19/2/12 at 08:47 PM
is the p100 diesel clutch plate the same anyone ???
Jamster1233 - 20/2/12 at 08:51 AM
Does it have to be a 230 mm what about the 240 mm ???
