Hello
I have been asked by a few people how I routed my exhaust out the back in an effort to cut down noise.
3" pipe all the way through so:
From the front
Exhaust from front
Under the arch and turned in front of the rear bulkhead, 4" hole
can back
Under arch
It goes behind the seat, boxed in of course
bulkhead box
Through the rear bulkhead, this is an elongated hole as the curve runs through
through bulkhead
It then kinks under the halfshaft
under halfshaft
Then out the back
Exhaust rear
The purpose is to remove engine and induction noise as I have struggled to pass track day limits.
Regards Mark
Similar to mine but I have slightly more clearence to rear tyre and I took mine under lower rear wishbone and back axle to keep away from Fuel tank. I
have loads of Clearence but my pipe work is smaller id
[Edited on 18/3/12 by daniel mason]
Built in seat heating too!
