I put in a startlet rad & fan into my pinto powered locost. How should I go about adding a fan switch? There is no hole or threads on the rad for
for a fan switch. What do I need to do/get.
Don't aks what year the starlet fan is (I'm not even 100% sure that it is from a starlet), I just picked it up from a pile of rads in a
junkyard and it looked like it would fit.
Hi, just seen your question and thought of these modules.
They go in the radiator hose and give a location for a stat switch.
http://www.merlinmotorsport.co.uk/COOLING-Hose-Adaptor/c20_312/index.html
Hope they help - and that the link works.
Len
as above
You would need a hose adaptor tapped for an M14 fan switch , you will find loads on ebay complete with switch or as bare adaptors that need
re-tapped to M14. M14 is the switch size used no older Volvos, Reanults and BMW and are cheap on eBay.
It might actually be cheaper to switch to a Polo rad which has a M22 hole ready made.
eBay is a much cheaper place to buy this type of stuff very close to half the price of Merlin Motorsport with free P&P
Alloy Water Temp Gauge Radiator Hose Sensor Adaptor Temperature - Select Size | eBay
BMW fan switch on ebay M14 thread 95/90c
Radiator fan switch BMW 3 series 5 series 7 series FREE UK P&P | eBay
[Edited on 4/4/12 by britishtrident]
Free rad not looking quite so cheap now. Thanks
You could get one made up for £10
or drill hole in the side bit of rad and weld a nut in to take sender unit.
