megasquirt triggerwheel problem
aidan46 - 12/5/12 at 07:01 PM
I've installed a 36-1 trigger wheel on a bike engine. If I get a spark generated at the spark plugs dose this mean it is set up correctly?
big_wasa - 12/5/12 at 07:12 PM
No it could still be out of time.
snapper - 12/5/12 at 07:20 PM
To elaborate it means the VR (crank position sensor) is seeing the missing tooth, the ecu is instructing spark at a reference to the map.
What you must be sure of is that the missing tooth is 90 degrees after TDC from there you set the spark map
If you have a spark that's a good start.
aidan46 - 12/5/12 at 07:31 PM
Yes, I think I have the degrees before tdc set right, but dose the fact I'm getting a spark mean the ecu is reading the 36_1 wheel correctly?
matt_gsxr - 12/5/12 at 08:20 PM
Have you got a laptop talking to the megasquirt?
If so then you should see some RPM on the laptop (running tunerstudio, or megasquirt software).
Spark is a good sign though.
big-vee-twin - 12/5/12 at 10:14 PM
The VR sensor should be 80 degrees not 90 using a 36-1 wheel.
See this link
MakeEverything - 13/5/12 at 09:37 AM
See this link
Depends where it's mounted. It can be anything as long as the software settings are correct to identify the offset.
aidan46 - 13/5/12 at 09:52 AM
Thanks lads had it mounted arseways!. Missing tooth was 220 degrees before sensor designated tooth.!
