1.6 cvh engine mounts
pmc_3 - 28/5/12 at 05:55 AM
Has anyone got any pictures of engine mounts for a fwd cvh into a seven style car? Do you need to drill and tap the side of the block for different mountings?
will121 - 28/5/12 at 06:17 AM
I have a 1.6 cvh fitted, will take some photo's when home tonight, but I used existing bolt holes in the block
pmc_3 - 28/5/12 at 06:36 AM
That would be awesome thanks! Did you make the mounts or were they ones you bought? Cheers
will121 - 28/5/12 at 05:17 PM
i made mine and added photo's to the album below, not easy to get a photo of them but hopefully show where i mounted them on the block, mine fit different to the chassis as in a locust but you should be able to do something similar
photo album
[Edited on 28/5/12 by will121]
pmc_3 - 28/5/12 at 09:40 PM
Cheers! Anyone else?
pmc_3 - 3/6/12 at 04:15 PM
Must be someone else?
jwallbank - 3/6/12 at 06:58 PM
Hi,
My mounts came with the engine from a Westfield. Mountings bolted direct to block into original mounting holes.
John W
[Edited on 3/6/12 by jwallbank]
pmc_3 - 4/6/12 at 12:09 AM
Fantastic, thanks!
