Hello, I want to fit the below sensors into my block zetec blacktop,
My question is what are the thread sizes as I need adapters
One (I want to put the pressure se roe here) on the inlet site just along from the standard pressure switch which has a torx bung in it
The other on the exhaust site just along from the crank sensor ( want to put the oil temp sensor here) had a 10mm socket plug in it.
http://www.race-technology.com/content.php?pcat=2&cat=67
http://www.race-technology.com/water_temperature_2_65.html
