Twin weber throttle linkage
IanSouthLincs - 3/2/15 at 11:20 PM
Hi Guys 'n Gals
Going to be needing a new linkage as above soon and was thinking that the Sytec twin cable assembly TLK2/W looks good value. Any info good or bad very much appreciated, also alternatives welcome too.
Like this one:
Sytec Weber 40 45 48 DCOE Twin Cable Throttle Linkage Kit For Twin Carburettors
Ian
prawnabie - 3/2/15 at 11:22 PM
Will you have enough room for a top mounted one?
IanSouthLincs - 3/2/15 at 11:32 PM
I'm 95% sure a top mount one will go in, but can't find any specific height measurements, so it is a guesstimate!
AvonJas - 4/2/15 at 10:21 PM
I've got a sytec linkage on my carbs, slightly different design to that one. It works fine, and measures 47 mm in height
IanSouthLincs - 5/2/15 at 03:38 PM
Avonjas that's great info thanks, are yours the black aluminium ones, apparently they've changed from the silver coloured ones.
