Idle Issue
wrxseeker - 13/7/15 at 01:18 PM
My car is fitted with a Sierra 2.0 8V DOHC with the stock engine management and injection.
Recently when starting from cold the idle has been going to around 1800rpm before dropping back down - if you then blip the throttle, the idle sticks again before dropping.
This carries on until the engine is warm and the ignition has been swiched off once - it then idles perfectly as it always did.
If you disconnect the ISCV wire when its doing the high rev thing it idles at normal idle even when cold.
I think the ISCV is working ok but something is telling it to hold the revs high - any ideas what is what ?
I think it started doing it after fitting a new alterantor belt but cant be sure exactly when it started.
BaileyPerformance - 13/7/15 at 01:21 PM
Check the TPS is working correctly.
Dingz - 13/7/15 at 01:27 PM
Take the Idle control valve off and give it a good clean out with carb cleaner or similar.
big_wasa - 13/7/15 at 01:30 PM
As above, I'd should stall dead with out it connected.
