Today I de-pinned all the engine loom plugs for my Blacktop Zetec so I could route them through a grommet into the engine bay, plus I shortened a load
of them now I know how long they need to be. The trouble is now I have checked all the wiring and that’s ok but I have a conflicting diagrams in
regards to how the HO2S plug is wired pin to pin.
What I have is one that shows:
Pin 1: Green/Blue (Pin22 from C2513 plug to switched live)
Pin 2: Black/yellow (Pin 93 on ECU
Pin 3: Brown (Common Earth)
Pin 4: White (Pin 60 on ECU)
And the other one has
Pin 1: Black/yellow
Pin 2: Green/Yellow
Pin 3: White
Pin 4: Brown
I know where the wires go to and what they do, I just need to get the correct wires into the correct pin location for the sensor which is wired:
Pin 1: White
Pin 2: White
Pin 3: Grey
Pin 4: Black
Could anyone please have a look at what they are running and let me know the correct way to wire the plug again
[Edited on 27/11/15 by tims31]
I will double check in the morning for you, remind me if I foget.
The two white wires are the heater and can be wired either way around.
Hey Warren,
Just a reminder for you mate, any luck finding the wiring for the HO2S plug please?
Originally posted by britishtrident
Standard NTK/NGK Zirconnia sensors and some Bosch
Black = Signal
Grey = Sensor Ground
White = Heater + Supply
White = Heater Ground
Whites can be wired either way round
Yep looks like your sorted. Sorry for not getting on it but I've not been well.
No problems Warren, get well soon.
