Right! Been trying to find a cooling system layout for a silvertop Zetec, using a heater that appears to work fine. However there seems to be millions
of versions out there of what is right and wrong!
Can anyone advise which is the best version to use please?
I am using a header tank and not using a water rail. Heater also fitted.
Thank you
http://www.locostbuilders.co.uk/viewthread.php?tid=177349
This is pretty much the same layout I put in place 13 years ago...
[Edited on 31/10/17 by stevebubs]
Heater taps in to the back of the thermo (not shown but its there) and its return is tee'd on to header supply.
[Edited on 31-10-17 by loggyboy]
Yup - the above is the same as mine. However I just have a manual bleed screw in the Radiator, no pipe from the rad to the header tank.
where is the best place to plumb the heater into? I cant put a bleed pipe in the top of the rad as it is a plastic Polo rad. So take it off the top hose instead?
Heater runs out of the back of the thermo housing and returns into the bypass hose. That's the oem setup.
Mine is same as the pic but without a bleed on the rad. My issue was caused by expansion tank filling up full. Been fine since new bigger tank.
Get the expansion tank high a possible or it won't bleed
[Edited on 31/10/17 by jossey]
cheers for all the help, will get it sorted shortly!
I have done the cooling as per Loggyboy's image. However when I turn the engine off I get some gurgling now! Appear to have all the air out, but
the header tank does fill up when running!
Do I need a bigger header tank or still got air in the system? I'm going to raise up the header tank as much as possible tonight too.
I have T'd the heater return and header and the bypass all into 1 feed into the bottom hose. Should I have 2 separate ones really? Cant see it is
going to make any difference though!
Also I'm not running the rad bypass as the rad doesn't have one, is this an issue?
Originally posted by ttalps2000
I have done the cooling as per THE THIEF@S image. However when I turn the engine off I get some gurgling now! Appear to have all the air out, but the header tank does fill up when running!
I have T'd the heater return and header and the bypass all into 1 feed into the bottom hose. Should I have 2 separate ones really? Cant see it is going to make any difference though!
the only thing that is not as per the image is the rad top bypass back to the top of the tank. However several users have stated they do not run one with no issues anyway! so was simply asking what it does and does it matter and also that the main bypass, expansion tank and heater are all run into 1 connection to the bottom hose.
So is the cooling issue solved?
