2 bike engines.. V8?
akumabito - 15/1/05 at 09:56 PM
Ok, so some time ago, I came accross the site www.motorbau.de and when I saw that twin bike engine V8, I thought it was the greatest thing on earth.. so I thought I'd share it with you guys, but right before I posted it, I did a search, and I saw it was already mentioned in this discussion.
There were some interesting ideas in that thread, but since it's about half a year old, I decided to make a new thread, hope nobody minds...
In the old thread, NS Dev suggested that instead of joining the blocks together it would be far simpler, and cheaper to join the transmissions together, and have both engines drive the rear axle..
How would this work? How can you join two transmissions to share one driveshaft?
cymtriks - 15/1/05 at 10:14 PM
Cyclone were showing a V16 (four bike engines on a common crankshaft) on their stand at the autosport show last week. Awesome.
Strangely it had Callaway written on the cam covers though it was a cyclone engine.
stevebubs - 15/1/05 at 10:15 PM
www.zcars.org.uk
http://www.tigerracing.com/cars/tiger-cars.php
subk2002 - 16/1/05 at 12:34 PM
Does anyone know of any build sites,forums, about the bike engined mini's ?
Cheers Drew
[Edited on 16/1/05 by subk2002]
britishtrident - 16/1/05 at 01:32 PM
With two engines the torsional vibrations problems are not so much a leap in the unkown as a leap into the abyss -- really you don't want to go there.
akumabito - 16/1/05 at 03:09 PM
The tiger Z100 puts the engines back to back, to create 4WD, but how did they rig the front diff? Do they design and build their own, or is it an adapted (up side down?) diff?
On their site, they also say a transfer box combines the drive from the two engines.. but how would tht work if the engines are placed back to back?
Northy - 16/1/05 at 04:30 PM
I seem to think its an up-side down Granada diff, and it eats them!
stevebubs - 16/1/05 at 05:31 PM
Z100 is RWD only. Both engines driving the rear diff via a transfer box. This relies on good old mechanics to even out the power.
Z100WR is 4WD with each engine driving a pair of wheels (much like the Twin-Engined 1000bhp Ultima they've just built). These cars rely heavily on Motec gadgetry to allow them to go round corners
JoelP - 16/1/05 at 05:38 PM
yup, steve is right. the 4wd one is really 2+2wd, which i cant imagine handles well. The rwd one uses the transfer box.
i wish i could find more online help regarding twin engined cars, with so many grassers using them you would that there were more tried and tested ways commonly known.
the hardest bit im finding is getting the transfer box sorted, what with the need for oiling and a cooler. Someone suggested tapping into the engines oil circuit, which might be a solution - but i still cant work out the best way splatter the oil about inside the box.
stevebubs - 16/1/05 at 05:55 PM
Cyclone V16
Cyclone V16
Destined for a Corvette Apparently....commissioned as a technology exercise by Callaway.
If you want you're own version, you're looking at bills the wrong side of £50k (Ouch!!!)
Oh..and the V8 engine will shortly be available as a "Do It Yourself" Option whereby they supply everything except what you need from the 2 FZR1000 engines (heads, etc). You can then bolt it together yourself.....hmmm....
Cyclone V8
Cyclone V8
stevebubs - 16/1/05 at 06:01 PM
Joel,
Are you on the Yahoo BEC list? Simon Ranson (owner of the original Z100) often lurks there when he's around. There's also a good wealth of knowledge on BECs in General.
http://uk.groups.yahoo.com/group/bike-engined-cars/
Alternatively, come find us in Le Mans - I think he's bringing the Z100 again this year.
Stephen
It took Z Cars a hell of a long time to get the transfer box reliable. I believe this was predominantly due to sorting the oil circuits.
Noodle - 16/1/05 at 06:02 PM
Brian Hart did a twin-FZR1000 conversion to V8 a few years back.
See http://www.locostbuilders.co.uk/viewthread.php?tid=5997&page=2
Neil.
phelpsa - 16/1/05 at 09:00 PM
The RST-V8 caterham was at the autosport as well.
Adam
chbright - 17/1/05 at 07:13 PM
ask these guys
they could give u some info possibley
