Hi all
I have just started buidling a honda s2000
engined locost and I am planning on using a di deon diff and I was wondering if anyone had any pictures or drawings of a de dion setup or info on
honda engined locosts.
Originally posted by speedys2k
info on honda engined locosts.
The diff used with most dedion axles is the good old Sierra jobbie...
You won't find many traditional rwd cars using Honda engines (ones that originally had a transverse application anyway) because they rotate the
other way than standard which would be ok if you wanted 1 forward gear and 5 reverse
Obviously the s2000 lump/box will be diferent because of its rwd configeration.
THIS will probably be of some use.
HTH
G
[Edited on 11/5/05 by Mr G]
