fuel tank plumbing/return line/breather
ned - 14/5/05 at 09:09 AM
Have been looking at the plumbing layout for my fuel tank, it has pickup outlet and one return line, is it possible to put the breather/one way valve on a directional t-piece on the return line near the tank or do i need to have a seperate breather outlet on the tank?
the tank design was originally for a carb install and now i'm using injection hence the uncertainty.
thanks,
Ned.
Northy - 14/5/05 at 11:20 AM
Ned,
Has it got a built in swirl pot? If not are you fitting an external swirl pot? You could plumb the return into the external swirl pot.
ned - 14/5/05 at 12:27 PM
Northy,
Yes I am using an external swirl pot, but that still needs a return line to the tank!
Spoke to bob and he's heard of people doing it the way i propose so i don't think it's gonna be a problem
Ned.
tks - 14/5/05 at 04:49 PM
your filler cap is that one lockable??/
don't think you need a tank vent valve...
TKS
