Zetec-S 1.25
CaptainJosh - 11/8/05 at 02:49 PM
Hi, I am planning on building a Locost running a 1.25 Zetec-S engine from a Fiesta.
I just have a few questions:
1. Will I have to change the sump to fit the type 9 gear box?
2. Does the engine fit in the book chassis with minimal changes to the engine mounts?
3. How high would the engine sit, would I need some sort of bump to fit the engine in with the hood down?
4. Would the later switch to a 1.7 Zetec-S require any major changes?
-Cheers
[Edited on 11/8/05 by CaptainJosh]
NS Dev - 11/8/05 at 02:57 PM
Can you get a bellhousing to link this engine to the type 9 gearbox? I'm guessing you can, as there is one available for the later 1600 blacktop zetec I think, but worth checking.
Certainly a good engine, but I can't help with the quesitons!
James - 11/8/05 at 03:11 PM
What sort of power output will a 1.2give you?
Enough to be worth the effort?
James
CaptainJosh - 11/8/05 at 03:18 PM
The 1.25 puts out about 80HP standard, but has an Alloy block, so weighs in at a tiny amount.
Danozeman - 11/8/05 at 03:22 PM
The 1.25's are very quick engines. The 1.7's are vairiable valves arnt they?
I reckon youl need a higher bonnet.
cosworth - 11/8/05 at 03:48 PM
1. No
2.Yes
3.Possibly
4. Not major changes but the crank will require machining to fit a spigot bearing
Surrey Dave - 11/8/05 at 03:53 PM
I wondered about this engine as it is lightweight, anyone got photo's , are we saying that this one needs the crank machining or the later 1.7.
Is it 16v?
cosworth - 11/8/05 at 04:00 PM
Only the 1.7 needs the crank machining the 1.25, 1.4 and 1.6 are OK. Engine weighs 82kg fully dressed. Rescued attachment zetec SE1.JPG
Surrey Dave - 11/8/05 at 04:03 PM
Its the same weight and size for all the 1.25 ,1400 ,1600?.
Do they need a special bellhousing ?
Nice installation, doen't look Locost though.......
[Edited on 11/8/05 by Surrey Dave]
cosworth - 11/8/05 at 04:28 PM
Pretty much the same weight give or take a couple of kilos. Special bellhousing is required available from shawspeed
cosworth - 11/8/05 at 04:30 PM
no I dont think that one was particulary locost it was shawspeeds 210bhp 1.6
[Edited on 11/8/05 by cosworth]
