just fitted a power pully to a 2.0 pinto now the engine runs but with hardly any power, idles well., and the pully is set to halfway..
Suggestions have i got the belt a tooth out? or timing?
just to add it did seem odd on cranking..(but was not sure wether the battery was a bit low..)
[Edited on 30/8/05 by robbydee]
if you've gone too the trouble of fitting a "power pulley" you need to go too the trouble of finding optimum timing, by...........
A) get your dial gauge and protractor out and set to whatever the cam manufacturer recommended then..........
B) get it on a rolling road, you could still prob find a bit more by swinging the cam timing a little.
If you are gonna do B you could miss out A but you need to do one or both.
Defo sounds like your cam timing is out.
[Edited on 30/8/05 by Jon Ison]
was deffinatly heading back to the rolling road, but would have thought that half way on the vernier was the same as stock on the steel.
So was expecting little difference..
with the odd sound on crank and lack of power but a 'fairly' normal idle..my money would be on a tooth out..
Have experienced same thing on the same engine!
did u put new belt on at same time.. same amount of teeth on both?.. been caught out with that too.
[Edited on 30/8/05 by Ketchup]
Could be the timing too advanced from the odd sound bit. Does it seem to stop the starter as it gets to compression?
Yep i'm thinking along the same lines as peteff.
I have seen this on a pinto before. Does the engine offer to kick back the wrong way as well?
As the previous post you need to set it up with a dial gauge and a protractor just to be sure its right. You'll need to know the timing of the
cam as well.
Good news on a pinto, you can't bend the valves with a standard cam. Strong idle, falt as a pancake = tooth out, for best results you need to centre that cam, ie crank at TDC, lobs on number 1 givening equel lift on both exhaust and inlet, then advance the cam by 5-7' and lock out. This gives a few up to 10% more bhp in the middle and loses a bit of top end.
So grateful fot the replys... have just moved the belt one tooth on the vernier. will try the car tomorrow.. and book the rr session...
