i looking for a clutch to mate a xflow to a type 9 box, i have searched but failed to find anything.
can anyone help? is it a mix and match of parts?
i could use some locost ideas too but am very desperate for a clutch
IIRC mixture of Sierra 1.8 CVH and standard xflow clutch should see you through...
The main thing you need is a 7.5"(190mm) dia clutch plate with a 1"*23 spline centre.
The release bearing depends on which pressure plate you have, for a curly finger pressure plate you need a flat bearing and for straight fingers you
need a curved bearing.
Rally design do complete kits for about £50.
ATB Dan.
The clutch on my car is from an early 1.6 sierra
Use the std type 9 release arm with the std bellhousing, all though if you go ally bellhousing like me you will need the RS fork or get a very nice
welder to mod the std one like i did
Hope this helps
Jason
