Kent sump mods
kango - 3/1/07 at 05:39 PM
I have just shortened my 1600 Kent's sump by 33 mm.
Questions :-
1) How far should the pick-up pipe be from the bottom of the sump?
(calculation showed old configuration ran at 12mm gap to the bottom of the sump)
2) I have the opportunity to baffle the sump. Any photos of how other people did it. Is it worth the trouble in a Kent?
3) Should I refit the mesh filter?
cryoman1965 - 3/1/07 at 06:02 PM
1.10-12mm should be fine. You need some space to allow a constant supply of oil for the pump.
2.A baffle would help, but i have no pics.
3.Refit the mesh filter. It is there for a reason??
N
jacko - 3/1/07 at 06:06 PM
Hi my engine is a pinto but the method will be the same
1 my pick up pipe is 10mm off the sump
2 yes it is always worth baffeling
3 YES
Jacko
kango - 3/1/07 at 06:34 PM
Thanks.
Who has some pics of the baffeling?
andrews_45 - 3/1/07 at 08:21 PM
there are some good pics on www.locost-racing.com build diary
kango - 4/1/07 at 06:41 PM
This is what I found.
kango - 4/1/07 at 06:43 PM
andrews_45 - 4/1/07 at 08:46 PM
this pic shows more detail of how he did the baffle
