Anybody recommend a place (cheaper than Demon tweeks) to get a oil pump plate for a remote filter conversion, i dont mean a sandwich one as i dont have room.
rally design?
http://www.rallydesign.co.uk/catalog/index.php?cPath=340_525
the items all say remote filler plate, but when you click on them it says 'filter'
£12 each +vat
was wondering if these existed today. measuring up my engine for the bay, and my steering collumn goes right through the filter
[Edited on 22/4/07 by blakep82]
http://www.v8tuner.co.uk/product.php?id=147
Not cheap but don't know how much the DT ones are.
If you ring Paul at V8 Tuner he may be able to sell the base plate separately, or recommend a suitable replacement
You could try a 101 filter housing, turns the filter up into the engine. It has outlets for an oil cooler, blank these and drill out the bypass hole. should cost £50, only other thing required is a gasket, no hoses and all that other expensive stuff
unless I am mistake, there are 2 types of base plate for the RV8.
One is effectively an take off plate as used with an oil cooler with an additional plate that replaces the oil filter and block of oil floing out of
hte take off plate.
the second is a complete cover with two holes to whcih the hoses go - this is more compact thant the above item but being engine specific, it costs
more.
see www.thinkauto.com for what I recon are the best prices -they after all manufacture this stuff and sell it to DT, RD and others.
Yeah its the second option i'm after, a blanking off plate with just the two hose connections, D.T. want £90 ,which in real money (he he) would
cost me best part of 150 euro.....damn euro, makes everything look soooo much dearer...
[Edited on 23/4/07 by gixxerpat]
I got one of these a couple of weeks ago from Real Steel for around £45 +VAT. It came with an adaptor that goes where the filter normally lives, a new filter housing (with mounting holes) and a pair of long hoses to join the two together.
