1.3 x-flow timing setting
myeates - 1/5/07 at 06:52 PM
hi guys does anyone know how many degrees before top dead centre the above engine should fire as mine is going at 0 so needs sorting
thanks guys
britishtrident - 1/5/07 at 08:03 PM
Depends on a lot of things --- try giving it 10 degrees BTC at idle with vac adavance disconnected.
lukefab - 1/5/07 at 09:40 PM
Yes I second that,did mine at the weekend and what a difference.
Disconnect vac pipe and set timing at 10 degrees BTC.
myeates - 2/5/07 at 08:32 AM
thanks guys 10º it is will sort this weekend
thanks again
