fuel pipe
d8mok - 22/5/07 at 01:28 PM
my fuel tank has a piece of clear pipe that shows how much fuel is in the tank. Over the last couple of years its become hard to see the fuel level so whilst the car is in bits i thought i'd replace it. However i cant find a replacement anywhere. some1 did tell me its illegal to use plastic pipe for fuel but i'm not sure.
basically i need a piece of clear pipe 8mm diameter and about 10 inch long. suitable for unleaded fuel?
pls help
Bluemoon - 22/5/07 at 01:53 PM
I have seen clear petrol pipe, at least as flexable pipe with reniforcing strings, ring a few motor factors? Might do the trick?
Dan
djtom - 22/5/07 at 01:59 PM
Try a lawnmower / strimmer / garden machinery repair shop. They use it as flexible fuel pipe from the tank to the engine, and if it's ok for that, then it should be ok for your needs.
Tom
myeates - 22/5/07 at 07:09 PM
may have some laying around will have look in morning seem to remember seeing it a couple of weeks ago probably cant find it know
myeates - 23/5/07 at 06:10 PM
guess what cant blummin find it now sorry about that will come across it when i dont need it
