Pressure Reg location Q
Simon - 1/6/07 at 10:46 PM
Chaps,
I've got to fit my fuel pressure regulator, which I gather goes between fuel rail and return feed.
Is it best to put it on the engine close to fuel rail or on the transmission tunnel?
Simon
nitram38 - 1/6/07 at 10:47 PM
I have only ever seen them on the end of the fuel rail, hope that helps
DIY Si - 1/6/07 at 11:11 PM
End of the fuel rail is prefered place. After all it's only there to maintain the pressure at the injectors.
Simon - 2/6/07 at 12:11 AM
Near fuel rail it is then
Tomorrow. Bit late now
Simon
stevebubs - 2/6/07 at 02:03 AM
FWIW, I've got mine mounted on the Fury's scuttle - about 8inches after the rail.
graememk - 2/6/07 at 07:58 AM
again mines on the return to the tank after the rail.
Mark Allanson - 2/6/07 at 08:54 AM
Needs to be there for the vacuum connection
Simon - 3/6/07 at 12:55 AM
Or boost
Simon
