What petrol do you use in bec's
mad dad - 21/7/07 at 05:37 PM
As above never sure whether to use Shell V Power or BP equivalent or just run on normal 95 octane?? does it make any difference to performance on a bec......i know it use to in my Subaru but would be interested to hear what people use....Cheers Andy
bigrich - 21/7/07 at 05:47 PM
the standard 95 octane is more than enough for a standard bike engine.
if its been tuned,compression increased etc then the super stuff may benifit it
all IMHO of course
mad dad - 21/7/07 at 05:49 PM
its dyno jetted but thats all thats been done......
Jon Ison - 21/7/07 at 06:02 PM
all IMHO of course
What he said, anything else is a waste of money.
Hellfire - 21/7/07 at 06:05 PM
What they ^^^^^^ said.
Phil
mad dad - 21/7/07 at 06:07 PM
that seems sorted then i'll go with what they said above
DIY Si - 21/7/07 at 06:24 PM
According to Haynes, my bird is specced for a minimum of 91 RON fuel!
BenB - 21/7/07 at 10:43 PM
I use cheap and nasty RON95... When I fit the 'charger however, I may have to upgrade to RON98!!!!
graememk - 21/7/07 at 11:38 PM
i cant tell the differance
tks - 22/7/07 at 05:16 PM
offcourse you can tell the difference but only in your pocket...
tks
ChrisGamlin - 24/7/07 at 12:57 PM
I generally use V Power / BP Ultimate etc in my injected R1 on track but only because I've got a PC3r Power Commander which adjusts fuel and ignition, and the map Im currently running is from a similar race car setup which I assume was probably set up for 98 RON.
Unless you adjust the ignition advance on a rolling road to suit the fuel (not possible on a standard blade engine without an ignition advance gismo or you convert to throttle bodies and mappable ignition), or your ECU is self adapting to suit the fuel being used (which hardly any if any bike engines do) then there's no performance benefit, although there may be a cleaning benefit as the premium fuels tend to have better cleaning additives in them, especially when compared to supermarket fuel.
chockymonster - 24/7/07 at 03:22 PM
If it's the map you gave me then it has the standard PC3R R1 engine timing, advance has not been adjusted at all.
ChrisGamlin - 24/7/07 at 06:09 PM
It probably is! I must admit Ive not looked at the map Im using since I put the R1 in as the laptop I used originally is now dead and Ive not needed to change anything since so havent installed the Power Commander app on my new laptop. I thought both ignition and fuel had been altered seeing as it was generated on a rolling road originally, but maybe Im imagining things. Still, thats good news in a way as there should be some minor improvements if I ever get round to setting it all up properly on a RR!
DIY Si - 24/7/07 at 06:25 PM
Do many bikes have knock sensors? Mine does, but quite as to how much the engine uses it, I don't know.
ChrisGamlin - 24/7/07 at 07:29 PM
Not many I dont think, certainly none that I know of. Maybe its trickier to detect at the higher rpm of a bike engine?
