Anyone know where I can get an 1/8" BSPT Male to 1/8" NPT Female adapter ?
Need it to fix Oil pressure sensor to the block.
LMA
http://www.lmaperformance.com/motorsport/Products/Gauge_Fitting_Parts/gauge_fitting_parts.html
Watch out for installing an oil pressure sender on an adaptor, in the side of the block. I killed an engine when the adaptor split due to the weight
of the sender / vibration.
I'm using a stainless hose from the block to the chassis, where the sender is fully supported.
HTH
Mike
[Edited on 20/11/07 by Guinness]
had the same problem myself. remote kit is a godsend. the vibrations are reduced too so the sender doesnt work itself loose anymore.
www.thinkauto.co.uk
it's online but you need to look for it
makers of mocal
grtz Thomas
thomas beat me to it - they claim to be able to make any adapter to.
