how do you make your own adapter plate for transmissions
Weld the two bell housing together with care f they are ali
Here's mine, Rover V8 onto Audi box
Its then sorting out the clutch.
Here is my effort, Getrag front gear casing to Type 9. Ignore the flowers
Steve.
Picture linky
Mark if you put that in the 7 where will you sit?
what about the spigot bearing and the shaft wouldent the shaft not sit in the spigot bearing if i added an inch on to the bel housing some thing like that
In front of it !
You need to have a measure up, this method used to be used to fit fiat twin cams into escorts years ago.
I am using the audi flywheel bolted to a rangerover flex plate
[Edited on 28/11/07 by mark chandler]
