remote gear lever info needed for race car
Iain Campbell - 9/10/03 at 10:27 AM
Hi..
I need info on remote gear lever, for x/flow 4 speed box, I need to bring it back 5"-6" nearer the driver, what do I need? or where to buy something..
thanks..
macspeedy - 9/10/03 at 11:47 AM
There are 2 ways, 1st you have a similar pole 5-6 inches further back working in paralell to the stick in the box connected with a horizontal pole, doesn't look very attractive the second is neater but requires you to beable to make parts on a lathe or buy them, heres the website with pics this is for type 9 not 4 speed, i am not sure what the difference at the gear selector but i am sure a simlar idea would work.
http://freespace.virgin.net/d.w.jenkins/gear_extend.htm
also
http://www.geocities.com/drusling/engine_main.htm#boxoverhaul
hope these are of some help
David Jenkins - 9/10/03 at 12:01 PM
I was thinking about blowing my own trumpet, but I wasn't sure what the back end of a 4-speed looked like! If it's the same as the 5-speed then it should work OK.
cheers,
Iain Campbell - 9/10/03 at 06:57 PM
Hi.
The 4 speed lever setup is different in a lot of ways to the 5 speed, I've looked up the web pages and saw how the T9 remote worked and then on mine, it will not do..I might have to change the box for a T9 and sell the prop and box and quickshift... :-( I was hoping to keep the 4 speed for weight reasons, and on the track or Hillclimb I never would need 4th let alone 5th..I was hoping someone would have the remote sitting in the back of the garage... building kits is never easy..
Iain Campbell - 10/10/03 at 09:20 PM
Hi
How does the remote setup effect reverse gear operation? what with the need to push down and over to the left?
Thanks.
