Does anyone know the valve clearance settings (tappets) for a 1600 crossflow. Tried searching everywhere but cant find anything.
Depends on spec of engine , do you know which one you have? has it got a standard cam? If not which cam?
Hi there, It has a road/rally sports high lift cam.
Cheers.
You might find the Kent Cams site useful. But you really would need to know the exact type of cam that's fitted.
Kent Cams
