my tin top is long over due has anybody used these service kits from ebay.
http://cgi.ebay.co.uk/Service-Kit-For-A-Ford-Focus-1-8-Zetec-2-0-16v_W0QQitemZ180178112027QQihZ008QQcategoryZ21654QQrdZ1QQssPageNameZWD1VQQ_trksidZp16
38.m118.l1247QQcmdZViewItem
and as the the car is 90k and needs a cam belt at 100k. has anyone tried these.
http://cgi.ebay.co.uk/Cam-Belt-Kit-Timing-Belt-Kit-Focus-1-8-2-0_W0QQitemZ270211977307QQihZ017QQcategoryZ21654QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m
will try mr patel down the road for a price for service items or is anyone able to sell ford service items at locost rates.
anyone have a manual in pdf format so i can look at doing the cambelt myself, and what else needs changing apart from the oil.
Make sure that the fuel filter is not the one shown because its not right for the 1800 and 2ltr petrol, they're the canister type by the fuel
tank!!
I'm in the trade so get all my bits cheap any way original or not , i used a powergrip kit from our motor factors £70+vat from what i can
remember everything you need idler tensioner and belt. Belts are easy enough to change tho!
Motaquip are a brand used by many independent garages and purport to supply to some OEMs so the stuff should be fine.
Motaquip were originally the service parts brand name of Chrysler UK--- bit like Unipart wasa to BL -- lord knows who owns the brand in the UK now.
I use the local motor parts place, if there are any problems you can take it back and I find that online prices aren't that much cheaper
My father inlaws tensioner failed at 97k smashing 16 valves. Best to do it asap
local motor shop done complete service kit all filters, plugs, oil, goodyear cam belt kit for £110 which cannot complain about.
anyone have a pdf instructions to replace cambelt or any advice do i need locking pins for cams.
There is a bar that fits across the back of the cams. IIRC its about 6mm thick and can only slot in when the engine is at TDC.
