Combustion chamber/piston cleaning
Benzine - 7/3/08 at 11:48 AM
I'm taking an engine apart and the combustion chambers/valves and pistons are a bit sooted up. I've got most of the carbon/soot/whatever off with petrol and a toothbrush. There's still some stubborn stuff there still, anything I can use to shift it?
locoboy - 7/3/08 at 11:52 AM
autosol and a polishing buff in a dremell type tool?
Benzine - 7/3/08 at 11:55 AM
Just googled imaged it, sounds good
Fred W B - 7/3/08 at 01:15 PM
Fine wet and dry paper with paraffine and a bit of elbow grease also works well.
Fred W B
r1_pete - 7/3/08 at 02:49 PM
For a lazier method, spray the bits with WD40, repeat a few times, it does soften the carbon deposits, making removal easier.
Worked well for me on some bike pistons and valves.
RazMan - 7/3/08 at 03:16 PM
Another vote for Solvol Autosol - I've done loads of bike engines like that. The shinier the finish the less 'sticky' it will be for the carbon.
Benzine - 7/3/08 at 03:18 PM
Just back from town, got some autosol, just the ticket! thanks
rusty nuts - 7/3/08 at 06:57 PM
Gasket stripper will lift carbon quickly but don't leave it on pistons for too long. Less effort than Autosol as well.
ReMan - 7/3/08 at 08:11 PM
rotary wire brush in the drill type thing.
Valves in the drill and emery cloth
Wood chisel to scrap the pistons.
Benzine - 7/3/08 at 09:02 PM
Is gasket stripper the same as paint stripper? I looked on ebay for some and some of them are shown as "paint and gasket stripper"
