and why?
I always find the one the car was designed with is best. Why? Cos the other one wont run right.
I think they're just the opposite of each other aren't they
1-3-4-2-(1-3-4-2)-1-3-4-2
1-2-4-3-1-(2-4-3-1)-2-4-3
^^^ well yeah.
1342 fires the middle cylinder before its outer neighbour whereas 1243 fires outer cylinder before its neighbour.
are you trying to suggest you even have a choice?
^^^ yes there is a choice. 1342 is used on vast majority of engines with Ford using 1243 in the past.
Porsche use a different order on their flat fours but we'll ignore that since it is not an inline 4.
Tuned crossflows do sound nice , dont know if its due to the firing order, zetecs are 1342 as most other engines and dont sound the same.
Paul.
Ok, which is better for a 4 cyl boxer - 1,4,3,2 (VW) or 1,3,2,4 (Subaru)?
(I know the answer before anyone takes my head off)
In effect they are the same --- 6 cylinder firing orders are more complex.
Paul.
well if we are playing silly games, I know of somebody running a 4 cylinder vauxhall race engine with 1&4 - 2&3, as a twin...............
obviously couldn't decide which order was best so removed the debate!!!
get into vee engines and it all gets far to complex and annoying, what with unequal firing angles and all that caboodle!!
[Edited on 17/3/08 by NS Dev]
Originally posted by Coose
X-flows are 1342 also,
The Kent crossflow (and I think Valencia and HCS) has a firing order of 1243.
I was hoping there was a proper reaosn like one is smoother. less stree on the crank or will run cooler etc. but I just don't see it myself.
Whoever designed the crossflow may have had a good reason for doing this - could be something ridiculous like the igntion leads are shorter than for
1342 so saves 20 p!!???!?!
that is wasted spark though.
big bang theory , 2 cylinders firing at the same time .
of half a nascar v8 in a class 9 .
Which is 1342 if you stand at the other end! Therefore, no real difference.....![]()
Xflo is 1-2-4-3
Fords were traditionally always 1-2-4-3 going back to the Model T perhaps even earlier.
Lotus-Ford Twincam wasn't a Ford design Chapman paid peanuts to Harry Mundy & Richard Ansdale to design it. JAP assembled it.
http://www.hemmings.com/hmn/stories/2006/10/01/hmn_feature25.html
Deleted because I just really can't be bothered any more. No really, I just can't.....
[Edited on 18/3/08 by Coose]
To put it another way, look at the animation here: http://www.cybersteering.com/cruise/feature/engine/engine.html
This is a 1243 engine and the firing order is 1243 no matter which end of the engine you call the front. There is no way this pattern can be described
as "1342".
Dynamically the two are absolutely identical though (in terms of balanced and unbalanced forces and moments) and there are thereofre no mechanical
advantages of one over the other.
Edit: the tables at the bottom of that page show the fundamental difference. A line in the top table eg ICEP does not appear at any point in the
bottom table which ever way along the rows you read.
Top table is 1342, bottom is 1243.
[Edited on 18/3/08 by matt_claydon]
The Fiesta or KA sound is always around with 1243. That are really tough engines. So no problem. Maybe for balance, cooling, exhaust you could choose
a different firing-order.
But I prefer logical: 1342
regarding the exhaust an the desing of the primaries and the order in which they enter the collector you'd just need to make sure, that the
pulses line up to aid scavenging from the cylinders.
for both firing orders discussed the orderof collector entry is the same, the target is to recieve the exhaust pulses into the collector in an orderly
fashion ie 180 degrees appart
when firing order is 1-2-4-3,
cylinder:
1 needs to be next to 4
2 needs to be next to 3
4 needs to be next to 1
3 needs to be next to 2
when you make the same list for the firing order 1-3-4-2.
cylinder
You'll get the same list of the only thing is that the 4 ports on the collector fed in reverse order of the first firing order, which is the same
thing as phisicly rotating the collector 180 degrees. taking the headers with it (IE twisting it around)
they both end up being 180degrees systems. think of the cylinders as 2 pairs. outer two running 360 appart and the inner 2 also running 360 appart,
in other words the reason for the difference in engine note cannot be this change in firing order. unless the exhaust system is phisicly different in
desing.
grtz Thomas
[Edited on 19/3/08 by thomas4age]
