i have a 1.8 zetec from a mondeo, i have heard that i can put in 2l cams to up the power. is this right? if so is it a straight swop or do i have to
chage other bits as well??
Rick
you can drop in the cams and followers out of the 2L. i have a set of 136 cams in the shed that i put in a 1.8 but i had them back out when i scraped
the engine so they do fit.
adam
Its only worth doing if you have the lower powered version of the 1.8L as there were 2 versions
Have a look under here if you are unsure of which version you have.
does it make a big difference?
Yes its is a very noticable improvement, but if its a blacktop engine you'll need to reshim the followers.
Can you put 2L black top cams in a 1.8 silver top ?
Originally posted by ricklawn
i have a 1.8 zetec from a mondeo, i have heard that i can put in 2l cams to up the power. is this right? if so is it a straight swop or do i have to chage other bits as well??
Rick
