English axle
sprouts-car - 2/6/08 at 03:54 PM
I'm looking to order a prop shaft and need to know the bolt pattern for an English axle flange.
I'm sure many of you have had to find this info before.
Have done some searching but no luck.
-and / or-
Does anyone have any prop shafts for sale. Looking for a type 9 to English axle one.
Thanks,
Chris
stevebubs - 2/6/08 at 03:58 PM
Just to add confusion - is your axle big or small flange (there are 2!)
sprouts-car - 2/6/08 at 04:01 PM
Bother!
sprouts-car - 2/6/08 at 04:28 PM
I seem to remember it the bolts were 45mm on one side and 55mm on the other. ie in a rectangle.
not sure though about that
Chris
mr henderson - 2/6/08 at 04:30 PM
You might find that the prop-shaft people know the answer already
John
001Ben - 2/6/08 at 05:34 PM
I think the large flange is 109mm and the small flange is 96mm
David Jenkins - 2/6/08 at 06:06 PM
In my case I just told the propshaft man the diameter of the flange and he was happy.
When I got it, it fitted perfectly.
Werner Van Loock - 2/6/08 at 07:13 PM
Very good topic, I also need one T9 to english
group buy anyone?
sprouts-car - 2/6/08 at 07:17 PM
group buy anyone?
Well thats 2 of us. Anyone else?
Danozeman - 2/6/08 at 07:17 PM
If you use one of the well known places they will already know. Just tell them the diameter as David says. Mine came from dunning and fairbank and they I told them type 9 to english axle. measured the flange while i was on the phone.
They7 need that and the length from tip of box to the diff flange.
Job done.
sprouts-car - 2/6/08 at 07:58 PM
Job done.
How much did you pay for it (If you dont mind me asking)?
Chris
